hi, i have a 17,5gb of free hard disk that means that i can record in avi 40 minutes only, so what should i do to record other 40 minutes and put them into a cd? i mean if i run nero and burn the first 40 minutes it doesn't allow me to put anything more!
what can i do???
please help me!!
thanks
You need a better codec which allows you to compress a little more. I would really recomend the Huffyuv 2.1 Codec (download on the on the tool page) You should be able to record a lot more than 40 mintues. See in your capture application if you can set the compression used while capturing. And change that to something less sizedemanding...
Thanx/
Lars -
I use the codec that came with my graphic card. The "Asus Video Compression" I get about 100 Mb for 3 minutes. in PAL standard.
Remeber that if you're running Fat16 or Fat32 files system you will bump into the 4Gb limit too.
Thanx/
Lars
Trying to burn a dvd using dvd shrink and Nero 10, please help a newbie?
By KtuluAlly in forum DVD RippingReplies: 6Last Post: 30th Dec 2010, 13:33 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
Newbie Needs Some Help Using Nero 9 to Improve TV Recorded DVDs
By suzanne27 in forum RestorationReplies: 5Last Post: 18th Mar 2009, 20:45 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Nero help for newbie IDIOT
By bbassboat in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2008, 17:32
