Hi, I am using the dvd2svcd program and I am using TMPEG for video Encoding. I am using 2pass VBR and motion search precision as "highest quality". TMPEG says it expects to take about 20 hours to finish encoding. This is a 100 minute movie. Is this normal? Is it supposed to take this much time?? Am I doing anything wrong? Should I change some setting? Thanks.
depending on your computer YES.
but you didnt fill out your computer info so we dont know what u got.
i can do a 2hr20min movie w/ cbr in about 10 hours -
suggestion- lower motion search to high quality instead of highest.
Im my experience there is no difference(quality wise) except highest takes longer -
Why not use Cinema Craft Encoder and go a lot faster. If you can somehow play the MPG out to TV from your PC you'll want to have CCE do VBR one pass (0-9800) and go 2.5 times realtime.
AWESOME!! -
How much time will be needed to convert 130min movie? is it that long? what's the software that can convert it in a shorter time?
How to keep track of how many hours PC has been used/on ?
By Noahtuck in forum ComputerReplies: 9Last Post: 3rd Apr 2012, 10:05 -
Which SD Card? How Many Hours?
By josel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 18th Sep 2011, 17:11 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 12:08 -
3 Hours.. HELP!
By Its Pink Ninja in forum Newbie / General discussionsReplies: 20Last Post: 15th Sep 2007, 19:33
