Hi
I'm an extremely newbie.I converted a dvd to vcd using TMPGEnc and it took about 5.5 hours the first try.I burnt it to a vcd and decided I wanted to try a couple different settings.Now I'm trying to convert it again and the program says it will take about 46 hours to run.I'm running a Pent 4 1.5 gig machine.The only thing I think I changed in the way I edited it was the
format.I went from full screen with aspect ratio 2 to just full screen.But I could be wrong.
Why would there be such a difference in encoding time from one try to the next?
wvlegend
I'm gonna smoke me some crawdads.But first I need a little pot.----Granny Clamppet
I think I figured out my problem.I don't think I had the program loaded right.I deleted TMPGEnc,reloaded it and bingo,4.5 hours to encode.
I'm gonna smoke me some crawdads.But first I need a little pot.----Granny Clamppet -
Glad you figured it out. Remember that the "quality setting" tab will have a drastic effect on the encoding length. Also, any filters that you use will also increase the encoding time.
Try encoding after a clean boot(or reboot) so your system will have more free resources.
How fast will a Intel 2500k processor convert 4 hours of avi to DVD
By johnharlin in forum Video ConversionReplies: 7Last Post: 9th Jul 2011, 22:01 -
Why do I have multiple files when I convert HD to SD using Tmpgenc??
By Endoking01 in forum Newbie / General discussionsReplies: 12Last Post: 9th Jun 2010, 22:43 -
It took 11 hours with TMPGEnc 3 to make a 2 hour video folder
By nhbfan12345 in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2008, 15:18 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 17:53
