    Oct 2002
    Hello all.
    Since my DVD burner doesn't arrive for yet another two weeks, I have been experimenting using the XSVCD format, and even DVD (burning a DVD image smaller than 700MB on a CD-R, that neither my CD burner or DVD player has any problems with). It seems that around 4500 bitrate, high quality source "drags", and turns slow-motionlike at times, causing the sound to stutter before catching up. And 6000 bitrate is like that non-stop. I've previewed all the files on the computer, and they look fine. Could it be that the lower density of the CD media makes it hard/impossible for the DVD to manage reading the high bitrates? Or am I missing something fundamental here?
    Hardware/Software used:
    iBook G3/500
    BitVice 1.2.51
    MissingMpegTools (why do I always get a Bus error when converting to MP2? Oh well, tried AC3 too, but got the same audio stuttering results when the video starts lagging)
    DVD Studio Pro
    Toast Titanium
    /Wizeman
    "I have not failed. I have only learned what does not work."
    -Edison
    Apr 2002
    USA!!!
    The maximum bitrate of an XSVCD is determined by your DVD player. I make XSVCD’s at a VBR of 4000 and they play fine in my RCA 5240p.
    Capturing Hi-8 and converting to an MPEG2 with that bitrate yields a very high quality image, like a DVD. The downside with a VBR of 4000 is, you can only get about 20-25min per CD. But with that qualtiy, I'll take it!
    Dec 2001
    Scotland, UK
    My player (Logix 3000) has a maximum of about 5000 kbps. Any higher than this and I get stuttering playback and sound drop-outs (even with miniDVD).
    You'll just have to experiment with different bitrates till you find the max for your player.
    MO, US
    That is essentially correct. A higher bitrate means that it has to read more data in the same amount of time. There is a limit to how fast the DVD player's drive can turn the disc, and it's usually much lower than the speed of a modern CD-ROM.
    Jul 2002
    BATON ROUGE, LA - U.S.A.
    sterno is right, problems at high bitrate seems to occur because the dvd player is having a hard time maintaining the rpm's needed to read the data.
    Where I walk, I walk alone. Where I fight, I fight alone.
    Oct 2002
    Thank you all. I checked w the details for my player (Denver DVD-311) here on the site, and it seems the max bitrate *is* 4000 for video when using CD as the carrier. Was kind of hoping to cram even more in there, but hey - I also read it supports DVD-SVCD and a bunch of other nice stuff so I'm not complaining
    On a sidenote, it feels wonderful to find such a live and vibrant forum. Posted before I went to bed, and when I woke up there was already a bunch of replies. I'm moving in
    /Wizeman
    -Edison
