Wanted to know if anyone is familiar with the Toshiba SD-3780 DVD player and whether it is compatible with either DVD-R or DVD+R. Called Toshiba product support and they weren't sure. They suggested I come here! Browsed thru the player section here and my player wasn't listed. Any help would be greatly appreciated because I am in the market for a DVD burner (they're getting pretty cheap).
Take discs to a store and try them.
My Toshiba 3755 plays DVD-R, DVD-RW, DVD+R and DVD+RW -
Thanks for the reply. I already have the player. I just want to make sure I buy the right DVD burner.
Probably will have best luck with a DVD+R
(I have one, and for $10 I will send you a movie on a DVD+R to test)
Or the SONY DRU500 that can do both dvd-r and dvd+r -
Thanks again! I just called my computer supply buddy 15 min. ago for some pricing on the Sony! I think I'm just going to go ahead and take a chance on the Sony. Appreciate the offer.
Toshiba drops HD-DVD.... Will 3DDivx-DVD fail ?
By ledishis in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2011, 15:42 -
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
From HDV Camcorder to DVD to Play in HD DVD Toshiba HD A2 Player
By fjmr in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Jul 2008, 11:04 -
Compatability of DVD+R DL media with LG LDA-831??
By jamiemark in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Mar 2008, 11:07 -
Toshiba DVD Drive does not recognize Philips DVD-R media
By garybeck in forum DVD & Blu-ray WritersReplies: 12Last Post: 5th Nov 2007, 13:57
