Hello ppl, this is my first post so i am hoping you can help.
the problem is ...
i downloaded film, avi file.
played in windows media player like normal
discovered that the audio did not match with the movie, the audio i was a about 5 seconds 2 fast
took me ages to download and no other versions are available
i used VirtualDub/ open video file, and says ...
"couldent locate decompresser for format 'DX50' (unknown)
VirtualDub requires a video for windows (VFW) compatable codec to decompress video, Direct Show codes as used by windows media player, are not suitable"
i dont know if this has any relivance to the solution
i have made vcd's before, and know how to encode, so i have some knowlege
hope you guys can help , it would mean a lot
signing off
Puddleboy69
Hi
I had the same problem with the audio,I used goldwave to solve the problem. If you open up the program,on the tool bar go to open and import the movie, this will then deflash the audio into the prog.after this go to edit, then down the list to insert silence,click on this a box will open enter the silence you require. This will insert the silence and move the audio on. After this save the file to wav. this will convert and you are now ready to encode. It may take a few times to get the audio right.
hope this will help
Script redirects to website when opening a downloaded AVI file.
By B Nasty in forum Newbie / General discussionsReplies: 15Last Post: 5th May 2010, 05:01 -
no sound with newly downloaded .avi file
By JediPM in forum MacReplies: 7Last Post: 30th Dec 2008, 15:29 -
I have downloaded file clips in .divx how can I convert to .avi?
By Ricksasha in forum Video ConversionReplies: 8Last Post: 13th Nov 2007, 13:36 -
Codec problems with downloaded avi files?
By aelfheah in forum Video ConversionReplies: 3Last Post: 16th Jun 2007, 07:48 -
AVI File Downloaded from torrent
By mps in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 10:54
