I'm trying to rip a dvd and I get the video fine but when I use DVD2AVI to try to set up the audio capture, there is no MP3 menu item under the Audio menu. I'm using DVD2AVI 1.77.3.
I'm thinking that this is why I 'm not getting a WAV file to go with my video.
Any thoughts?
Hi:
If you don't have MP3 menu, it should be (very probable) that no MP3 Codec is installed to use it in DVD2AVI.
Regarding the wav file, It is probable that you are not using the correct settings in the software. I don't remember well and I am not in my computer so I don't have the software in front, but I believe that you have to use dolby in the audio option and choose the right track from the DVD. Do not use MP3 if you want a WAV file.
Sorry I can not be of more help.
THX
8)
Rey -
http://arbor.ee.ntu.edu.tw/~jackei/dvd2avi/
get version 1.76 its stable and then give it another shot
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 18:37 -
need convert from audio caset to wav or mp3
By assi in forum AudioReplies: 6Last Post: 5th Nov 2008, 19:07 -
capturing audio on PC to MP3 or WAV format, which software ?
By ktnwin in forum AudioReplies: 3Last Post: 2nd Nov 2007, 04:13 -
Item missing from Windows Context Menu
By alegator in forum ComputerReplies: 4Last Post: 19th Sep 2007, 17:12
