I was just wondering what my mistake is. I follow the instruction in the vcdhelp guideline converting avi file to SVCD. This are the following steps which i have taken:
1. Converting the audio to wav file and save
2. Open TMPGenc and go to SVCD NTSC (fps 29.970)
3. Insert avi file and wav file
4. Settings as per normal (as instructed in the guideline)
5. Check birate rate - 2340 (2520 highest)
6. Encode
(In my environmental setting >External tool, I have change Layer2 to use tooLame so that i can get better quality).
During the process, I have no pop-up error message and i finish encoding the avi file to mpeg(or mpeg file). Went i try to play it on nero burner before i burn. The picture looks perfect but there is no sound. I wonder why? I read this forum lots of time and the main problem is that they did not change the audio to wav file but i did.
Could anyone help me out with this problem...
One more question, do i need to change the mpeg file to mpeg2 file in order to burn SVCD? If yes, How do i change it (I'm not sure whether this is correct or not. Before encoding, load the template and double click SVCD or VCD if i want to do VCD and then start encoding)? How do i get the good or best template for VCD and SVCD? Could anyone please send my good or great templates to me? I have no template and afraid to play around the setting.Hope you guys will help me out
Thanks in advance
David Cham
davidcws_2000@hotmail.com
Results 1 to 1 of 1
Problem with audio when converting AVI to MOV
By emmajane in forum Video ConversionReplies: 5Last Post: 6th May 2011, 10:23 -
Converting MP4 to AVI - Confusing Audio Problem
By visibility in forum Video ConversionReplies: 4Last Post: 29th Aug 2010, 17:02 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum ffmpegX general discussionReplies: 9Last Post: 18th Jul 2008, 17:50 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
AVI Converting Process
By nkneedeep in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 20th Jun 2007, 15:27
