I can rip extras and up until now I have just been changing the name of the extra vob files so they follow the sequence of the movie, so they just show up at the end, but it didnt work one one, and is there a way to put them at the end? Without my cheat method?
free the world
Are you using DVD2AVI to frameserv?
You could then just add whatever VOB files that you want to add after it has selected the default ones. -
hi,
i use dvd2svcd too, and i didnt know that just changing the name of the *.vob file worked like that- i assumed that the *.ifo file contained information on all the *.vob files ripped (simply adding another *.vob would not be recognised by the *.ifo.)
a little off topic, but if this is not the case, then could u theoretically just place intro *.vobs at the start of a movie, simply by incrementing the numbers? (i have dolby vob intros that would look sweet on some movies)
i dont know how else u could add extra's using dvd2svcd, cos it makes the cd 100% full, no room for extra's. im gonna try out your method though! sounds like it would work...
gavin -
another way to add extras is to lower the disc size in the bitrate tab, it will kick out the movie with enough room to manually add the extras, but you have to rebuild the svcd. And then I dont know how to put back in your intro and change screens though. I am trying to figure that one out now.
free the world -
you can add your intro and change cd screens in DVD2SVCD with the cd image tab. Change your files into mpgand then select them that way.
free the world
Adding controls to a swf (then adding to website)
By AshleyQuick in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2011, 03:02 -
Wall-E... remove extras
By gbabione in forum DVD RippingReplies: 7Last Post: 24th May 2010, 02:35 -
Deleting Extras with BD Rebuilder
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 27th Dec 2009, 23:10 -
Strip Extras?
By Cabal2000 in forum Blu-ray RippingReplies: 1Last Post: 6th Mar 2009, 06:51 -
Adding stripped extras to a DVD
By zdzdz in forum Authoring (DVD)Replies: 6Last Post: 20th Sep 2008, 04:38
