I was following a guide when I hit a wall. It got to where you import the m2v file and the ac3 file into DVD Maestro. However when I try to import the video it says
Media Not Supported Error (0xc10b0002)
Every time I load up Maestro it gives me this error which i just close and ignore:
Real Time Preview functionality will not be available because no decoders have been detected. (0x410a0011)
Is it just messed up? It imports the audio file fine just not the movie. Is there any other program to pull the m2v file and the ac3 file together in order to make a VIDEO_TS folder so i can make my movie?
thanks
XRacerGT
lets multiplex them to an MP(e)G Shall we?
get urself TMPGEnc(look under TOOLS on this site)
FILE
MPEG TOOLS
SIMPLE MULTIPLEX
VIDEO INPUT => YOUR M2V FILE
AUDIO INPUT => YOUR AC3 File
TYP: You can choose there, but i suggest you use MPEG2 VBR(cuz it gives better quality
Select an output file and hit the RUN button
from there on, follow guides from MP(E)G FILES to DVDWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 22:59 -
Muxing .m2v & .ac3 to .TS file
By randronoth in forum Video ConversionReplies: 3Last Post: 21st Jun 2011, 03:21 -
Is there a way to put a 'whole' DVD into a converted file?
By reapur in forum DVD RippingReplies: 5Last Post: 6th Feb 2011, 21:33 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
