thinking of getting a Zenix Z-315L player from local department store. its £120 and has all the features I'm after: cd-r,rw,mp3,vcd,svcd, 5.1 decoder....
However I'm after confirmation that it can be region hacked and Macrovision diabled, if at all possible.
Any advice would be appreciated.
Cheers in advance
Yes can be done using the remote.
If it is a H-315L-S
http://www.regionfreedvd.net/player/zenix.html -
is there a difference between the Z-315L and Z-315L-S ???
on the model in John Lewis it only says Z-315L
Does the hidden menu have a macro diable??
Cheers -
Do they have a unit for display in the store?
While you are "playing around" with it,
type in the above Code hack.
Or if they have a good return policy, try it at home
and return it if it does not work.
Is there an 'Off-topic' general IT/internet/media enquiry site on Facebook?
By jacknscoob in forum Off topicReplies: 0Last Post: 20th Jan 2012, 22:09
