Results 1 to 9 of 9
  1. When using TMPGenc to encode on one particular movie file it keeps say audio error detected. I have downloaded from another source but it says the same thing. How can I get around this?
  2. Banned
    Jun 2001
    UK
    Try Scanning the AVI for junk frames.
  3. How do I do a scan like that?
  4. I get the same problem.
  5. Banned
    Jun 2001
    UK
    KingJohns Guide to bad frames
  6. Thanks King John. Am using the guide and the file says 32534 frames masked (1 frame bad 32533 good but undecodable). Is that right?
    Apr 2002
    The State of Frustration
    You have a bad frame. Do you know how to delete it?
    Hello.
  8. No, I don't know where to begin.
  9. Banned
    Jun 2001
    UK
    If you used the normal Vdub, you dont delete anything, Vdub will do it for you.
    Video > direct stream copy
    Audio > direct stream copy
    SAVE AVI
    movie2.avi
    ITS IN THE GUIDE
