I would like to know if this DVD-player that I'm going to buy can play VCD.
It's from a cheap brand named Magnum, and I don't know the full name of the player.
However that this brand is sold in a cheap supermarket chain here in Western Europe it should be of good quality, because I already bought 2 perfectly working pc's there.
I also can't find a website from the brand on the internet, but I know the brand for some years know.
The site of the shop is http://www.aldi.be/ALDI_BN/home.htm (and then follow the link ALDI-buitenkansjes.
It can play DVD, music-CD, CD-R, CD-RW, MP-3, foto CD (JPEG-format).
If anyone knows something about this player please post it here.
Please help.
THX
Results 1 to 10 of 10
Most DVD players that can play CD-Rs should be able to play home made VCDs. However, if they have your model on display, why not take one of your self-authored (S)VCDs to the store and see if it will play it?
Hello. -
Yeah I know but that is one of the problems, this store sells these players all at one time and they don't have a display of the player in their store.
It is a sort of a one in a life-time buying chance. -
I would go the DVD Player section on the right and do some checking. Search for players that can play VCD, SVCD, XSVCD, CVD, DVD+, MP3 and whatever else you want to play. It will give you a list of know players that can do it. Then pick one and go buy it....
I have the RCA 5240p ($100USD) and it playes just about anytihng. Dont know if you can get that model over there or not....
Good Luck! -
Nope, I can't buy it over here.
But I will scoop a bit in the DVD player section and try to eliminate the players who can play cd-r, cd-rw and mp3 and can't play VCD and SVCD.
If they aren't with many I'm going to chance it and buy this Magnum-model. Maybe they can take it back.
But if you guys know more about this Magnum player, please post it here.
THX -
Aldi get most of its stock from Germany does it not !, maybe a look around the German sites may help ?
Big W, is also selling cheap DVD players, and the Philips (630 ?) there will play anything. -
Ah, well that's another thing... I did have a look around for you, and have seen the Magnum in our Aldi store (2 in Coventry).Originally Posted by matispiker
"Big W" is the larger "Woolworth" store
http://www.bigw.co.uk/ -
Well My daughter bought the Philips from Big W and brought it around here to test it, I tried everything, VCD, MP3, DVD rips, cam's NTSC, PAL and CDR-W and it played them all very well.
Wanna Play HD video Clip on my cell phone !
By augustya in forum Video ConversionReplies: 6Last Post: 3rd Oct 2010, 10:43 -
samsung 1080p9 wanna play rmvb movies
By phantomeduke in forum Video ConversionReplies: 1Last Post: 29th Jul 2009, 13:50 -
Wanna buy a new PC & TV Out card, suggestions needed.....
By SE14man in forum Newbie / General discussionsReplies: 0Last Post: 9th Nov 2007, 20:22 -
wanna capture some stuff but i can't.
By spoolintanabe in forum Capturing and VCRReplies: 7Last Post: 10th Jul 2007, 10:54 -
I'M DUMB and wanna RIP my DVD's WHAT TO DO????????
By notorious_jaye in forum DVD RippingReplies: 9Last Post: 19th May 2007, 08:29
