  1. Ok first i hope im in the right forum to ask this cause i'm
    a newbie to this cd burning.
    I have some AVI movies i want to add to a cd to play on my dvd player, now i know i have to convert them to a VCD Mpeg file first
    but my dvd player (according to the specs )does not play VCD but will play cd rw
    So does that mean it will play VCD if i burn it to a cdrw disc or does it mean i have to covert it to some other type of file
    I hope ive made sense explaining this
    Thanxs
    May 2001
    London, UK - Bonn, Germany
    Hi Kosh
    As you didn't state which standalone DVD Player you have it is rather difficult to advise you here. However the DVD Player compatibility guide is not 100% accurate. If it states that VCD's cannot be played (I presume the same goes for CD-R) but CD-RW's can it might be referring to, as you speculated, some other format. If however SVCD, XVCD, XSVCD are not listed either, I think it means it will play some form of audio CD-RW. Best thing to do is try, as you won't lose your CD-RW.
