I use virtualdub 1.4d+subtitle plugin to frameserve, then i use TEMPGEnc to make a SVCD whit subtitles.I burn them whit NERO 5535.The movie plays in my DVD Philips 751 whit the subtitles in sync but the movie are not running smoth.I convert from AVI 2 SVCD i tryed to make VCD allso and tryed different movies, but still the same problem. I hope someone could get me some help.
WHEN YOU SAY SMOOTH, DO YOU MEAN THE MOVIE IS JUMPY? IF THIS IS THE CASE IT SOUNDS LIKE YOUR FIELD ORDER IS WRONG. gO TO THE ADVANCE TAB IN TMPGENC AND CHANGE THE FIELD ORDER TO THE ONE YOU HAVEN'T USED. THIS COULD HELP THE PLAYBACK NOT BEING SMOOTH.
Right the movie is jumpy,thanx for your tip ill try that.
hope its the solution on my problem.
Strange demux situation whit tsmuxer
By penduleum in forum Blu-ray RippingReplies: 2Last Post: 20th Nov 2011, 21:01 -
S-Video Vs Composite for Black & Whit captures
By nharikrishna in forum Capturing and VCRReplies: 29Last Post: 8th Sep 2011, 23:30 -
VCR S-VHS whit entry YPbPr?
By saigo in forum RestorationReplies: 4Last Post: 14th Nov 2008, 04:15 -
decoding whit XVID or FFDshow
By technoplume in forum Newbie / General discussionsReplies: 0Last Post: 22nd Sep 2008, 14:24 -
PS3 XBOX360 whit not originl movie dvd
By MOPLASMA in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Sep 2007, 12:10
