I want to add permanent subs to my mpeg2 svcd movies. I have converted from avi and have mpeg2 files now.I have a .ssa subfile and would like some info how to multiplex them.Also how to cut the subs or to multiplex them, for som subs i have are in two parts ...?
Well.. virtualdub don't like mpeg2 files, and even if u get virtualdub to open your file i usually get problems when i try to Frameserve to Tmpgenc, audio syncproblems etc...Other talks about to convert the avi to mpeg2 with dvd2svcd and then add the subs with winsubmux.I'd like to try that, and i'm searching for a guide that tells me how ??
Thanks anyway... -
You may also add the subtitles to the AVI file before you frameserve to TMPGEnc. Using a wave file from Gold Wave to be used as an input audio to TMPGEnc when frameserving from VDub. But it is your video, so the choice ultimately is yours.
Hello. -
Originally Posted by Draven
Use MaestroSBT to convert your .ssa files to .sub + .bmp files.
Open winsubmux.
Select your input .mpg and set your output .mpg filename.
Select your .sub file and "Load All" to make sure you get no errors.
Multiplex.
Author and burn in Nero (VCDEasy doesn't seem to work reliably with subtitles).
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 09:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
