Hello,
I have a bunch of SVCD files that I have downloaded from the net and want to burn them onto DVD. I have done all the steps in the SVCD on DVD guide, but I would like to use a program other than Spruce to master the DVD for the simple fact I would like to have a "play all" button and spruce does not seem to have it. I have also tried to import them into DVD Workshop, which ends up reencoding them if I bring them in normally, and since it wouldn't bring in a demuxed file (wav + video), i'm kinda stuck in that area. So can anyone recommend a way to convert my SVCD files and burn them onto DVD with menus & a play all button? is their another piece of software which can author the DVD better?
thanks!
-Nick
theres neodvd but i dont think u can play all unless u combine all the mpg's into 1 big mpg. Goes the same for spruce
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 01:17 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 10:06
