I have Win 98se so I have a limit on file size. Using MMC MPEG2 for the ATI AIW I get two segments for a 90 minute movie. I noticed by accident that DVD2AVI will load both segments and make one d2v. Vut when encoding it is not seamless. Is there away to make the segments seamless.
You have a Pentium4 at 2.4Ghz but you still stick
around with OS from the 90's?
Recommend to bite the bullet and get WinXP pro upgrade.
Format the HD in NTFS to avoid the 4GB limit.
If you are a student, it will cost you $78 +$7 shipping
http://www.provantage.com/scripts/go.dll/ibuyer/fp_62583 -
Thanks TonyP, I will definitely take your advise. I just need to get the money. But how does windows xp pro compare to windows 2000 pro
nandi_nokuri,
But how does windows xp pro compare to windows 2000 pro?Warning! I'm baaaaaaaaack -
Hey KayFam,
I notice you hvae the same capture card as I do. Any capturing settings, suggestions. I like to record a few televisions shows and the encode them to divx, since someone said divx is better for watching on the computer.
Joing mkv files when they are not splitted at keyframes
By wateshadon in forum EditingReplies: 1Last Post: 11th Jul 2011, 13:01 -
Combining segments from different titlesets
By dt3kt in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2011, 13:28 -
How do I joing 2 files
By wan2no in forum ComputerReplies: 4Last Post: 16th May 2008, 23:46 -
Joing two dvds?
By Castor troy in forum DVD RippingReplies: 1Last Post: 10th Feb 2008, 17:21 -
Capture in segments...help for newbie!!
By wormdog88 in forum Capturing and VCRReplies: 0Last Post: 10th May 2007, 07:37
