If I burn data to a DVD-R or RW (such as an avi file), can I read that as a data file in a PC equipped with only a DVD-ROM drive? I was under the impression I should be able to but have failed dismally in my attempts so far. The PC doesn't recognise the disk as having any valid format. It obviously reads fine in the DVD burner that it was created on. Is it that a DVD-ROM drive will only read files in VCD or DVD format and normal CD data disks?
YOu can burn Data DVDs in Nero and read them fine long as you have a drive that can read DVDRs and good quality ones so that it doesn't error when trying to read them. Its how I back uped my computer for formatting.
Dvd-lab Read Data Size
By Burig in forum Authoring (DVD)Replies: 14Last Post: 19th Oct 2011, 20:41 -
DVD-ROM doesn´t read DVD
By jsilv in forum DVD RippingReplies: 11Last Post: 7th Mar 2010, 07:43 -
DVD Pro Lab - Error: Read Data Size
By lapetite_66 in forum Authoring (DVD)Replies: 2Last Post: 23rd Jul 2009, 15:48 -
VB code to read DVD Control Data Zone
By casejustin80 in forum ProgrammingReplies: 0Last Post: 28th Mar 2009, 12:34 -
How Do You Read the Data from a DVD Recorded on a Combo Unit?
By Junkman in forum Newbie / General discussionsReplies: 5Last Post: 4th Jan 2009, 10:27
