  1. Whenever I playback particular DVDRIPS, I notice occasional high-pitched beeps. Is there any way to remove these, and does anybody know why they're there in the first place?
  2. playback on what?
    A stand alone DVD player?
    With my Toshiba 3755 if I just as slightly go over the
    1150 VCD rate the sound start pinging like cracy.
  3. Banned
    Jun 2001
    UK
    Are they bleep's at the join of the Vob files ?
  4. King John,
    That's possible. They are usually accompanied by blocks on the screen,
    or discolorations, though. I'm not sure if this means anything.
    The beeps occur when I play the video on my PC thru Windows Media Player or the DivX player.
  5. Banned
    Jun 2001
    UK
    Yes, sounds like the join of the VOB's what are you using ? its not doing a very good job when it picks up the next VOB.
    I use Smartripper to rip, and Dvdx 1.7 to convert.
    They might not be all that bad on a DVD player...
