I have been ripping DVDs into MPEGs that I then put on VCD. I make them very high quality so they take up a lot of space. For example, the movie Memento takes up 1 gig. So, after I burn the VCDs I would like to store these somewhere. I don't want to use Divx because it is lossy. But, if is the best way, I cannot get Virtualdub to encode it because I have a hacked codec or soemthing.
I wouldn't consider a 1 gig movie to be extra high quality. Most 1 and 1/2 to 2 hour movies on 2 VCD disks would reach 1 + 1/2 gig.
If you are worried that they will be damaged why not make 2 copies or find a friend who collects like you and each keep a vcd copy.
DIVX, XVID, MPEG4, RM9, WME8 or 9 (WMV + WMA) are the only ones that compress enough and give decent quality.
If you want lossless then you are looking at many gigs per movie minimum 10 gig +.
Where in the world will you store that. Sorry but you must use a lossy codec from the list.
Picvideo is lossy too but I didn't list it because its does not compress enough.
I have many other lossy codecs but I have not tried enough so don't know if they would compress enough to fit the movie on 1 disk. A 2 disk compress would be useless since you may as well just copy your vcd.
I have been impressed with wme and rm9 in recent tests but don't expect to convert back to vcd easily.There's not much to do but then I can't do much anyway. -
Just an afterthought:
After you posed this question it made me examine something I have been wondering about for a long time but always forgot to try. Would compressing a mpeg using a program like winzip make a file smaller.
The answer using only 1 sample of 100mb with winzip 8.1 at maximum compression is a 3% smaller file. When I unzipped the file and played it I saw no obvious negative effects. I have an AVI that is just a bit too large for 1 cd. I will see if the same % is saved with avi files because that would be enough for that particular file to archive on 1 cd without overburn.
It would be interesting to see what other compressors (RAR etc..) achieve.There's not much to do but then I can't do much anyway. -
Originally Posted by gll99
OK, so how can I make this a high quality Divx? I mentioned my problem with VirtualDub.
Virtualdub warns you that divx is a hacked codec but does not prevent you from using it. The message only appears the first time you install it and use it. DIVX 5 may choke on it sometimes so I don't use it. In my opinion, DIVX 4.01 to 4.12 are more stable.
You will have to use filters to smooth the video and likely a bitrate of less than 1500 to fit your movie on 1 cd and it will take experimentation since each movie will be different. Remember AVI is a data format meaning that an 80 min cd will only hold a maximum of 700mb and not 800 mb like (s)vcd.
Personally I would cut my files with a freeware file splitter/joiner and burn the large piece on 1 cd. When I had enough smaller pieces from various movies I would put those together on 1 disk. I would write all the info and store a copy of the splitter program on each disk so I could rejoin the pieces at a later date. Forget all that reencoding for the sake of a few extra disks you will have all your original mpeg files.
Anyway, that's my 2 cents.
Have fun!There's not much to do but then I can't do much anyway.
Online Archival Format
By swiego in forum Video ConversionReplies: 7Last Post: 12th May 2012, 07:23 -
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 10:54 -
Best compression program/format/codecs without losing quality
By adrian2055 in forum Video ConversionReplies: 12Last Post: 20th Jan 2011, 15:29 -
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 03:00 -
Gold archival quality DL media?
By Disco Makberto in forum MediaReplies: 16Last Post: 13th Apr 2008, 11:22
