So I go to rip all about the benjamins and the vob files come out, but the sound is messed up, the first vob file has no sound and the other ones just have director commentary. I use smart ripper, any suggestions, or anyone know whats up? Thanks.
free the world
Pretty common that if you playback a single VOB that the sound
will not play back sometimes.
Select a different vob from the same rip and it have sound etc.
It also seems that you need to select a different audio track.
If you open up the Video_TS.IFO in powerDVD instead,
the movie should playback with sound. (so include that with the rip)
DVD decrypter is a little better too. -
I did try to play the ifo file, and it gave me an error. Said file 1 was not a correct file.
free the world -
doesn't really matter about the sound in the vob files....i'm assuming you're gonna encode it into mpg.
most of the time if you directly playback a vob, the sound isn't gonna be the right audio track...
just make sure you select the right audio track when you use dvd2avi -
yeah it is in process right now, but I didnt get any other choices of audio, well they were there, but I couldnt select them for some reason, that that I will care if it come out ok, I will report back when it is done tomorrow, and see if the image files come out ok.
free the world -
yeah audio seems fine now, but on a side note, I dont think it is incorporating the deleted scenes and outtakes like they did last time. I just change the file names to go along with the vob sequence. Worked the first time I tried it, but doesnt seem to be this time.
free the world
HUGE Ripping Problem...HELP
By mgbatman in forum DVD RippingReplies: 9Last Post: 27th Nov 2010, 02:41 -
Problem ripping ET
By audax in forum DVD RippingReplies: 8Last Post: 27th May 2009, 19:19 -
CD Ripping Problem
By ThePMonkey in forum AudioReplies: 4Last Post: 25th Jun 2008, 07:47 -
Problem ripping CRASH
By vice86 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2007, 10:27 -
DVD ripping problem
By borisblavasky in forum DVD RippingReplies: 3Last Post: 17th May 2007, 12:38
