  1. Hello. I have succesfully ripped a DivX to DVD using TMPGEnc, but now I'm trying my second (Jay and Silent Bob) on step 4 of 5 (Bitrate Setting), the size of the file is way too big for the disk (about 230% larger) and I can only reduce to a minimum of 115% larger, which is obviously still too large to copy. Does anyone know how to help?
    It would be very much appreciated.
    Probably has tmpgenc got the videolength incorrect so try select the source range(step3) . Click on source range and select only the movie, drag the bar to check where it ends.
  3. Thanks alot, I will try that. You've been most helpful.
