Is there a way with either TMPGEnc or Virtual Dub to resynch the audio on an mpg file when it is off. I thought I saw it here once before but cannot seem to find the tab in either to do it.
There's a Audio Delay corretion setting in the Source Range filter in TMPGenc. That fixed my Memento DivX to SVCD. The sound was 900 ms early.
Other wise I usuallt extract the Audio and edit it in an outside tool adn then merge the Video and Audio in TMPGenc!
Thanx/
Lars -
"There's a Audio Delay corretion setting in the Source Range filter in TMPGenc"
Where?? I have TMPGenc 12i
Also how did you work out the delay? -
I worked out the 900 ms by testing. It's not very hard to see if the audio was early or behind.. so I tested with -500 ms and it wasn't enough so then I tried another -400 = -900 and then it looked like it was in sync.. so I guess that was right.
The's a Filter in TMPGenc called Source Range, you check that one and dubbleclick to do the settings. Then under Audio Delay Correction you set the correction in miliscenods.
If you did'nt know there are filters in TMPGenc they are under the Advanced TAB in settings.
Thanx/
Lars
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
