My CD collection, mainly svcd's, is getting quite large. The CD wallet they're in is bulging at the seams. Does anyone have a better solution than this? I've considered CD sleeves, but haven't found a good way to store them. Any suggestions or links to products would be awesome. Thanks.
Something like http://www.mmdesign.com/orders/soft_case.htm. It could hold a ton of sleeves. Kind of pricey though.
There's never a solution, buy a nice CD holder that holds 200, and its no use a few weeks later. I'm thinking towards buying one of those containers.. you know the ones that are use on ships to transport goods
The answer is, get rid of the old ones I guess.. -
Here's what I did. I bought a caselogic case at half.com. It's supposed to hold 60 jewel cd cases...so I figure holding cd sleeves it should be able to hold close to 150. Then I'm going to number the sleeves and put together a master list of all the movies I have. Then I can put things like imdb ratings and movie length on the master list.
I'm hardcore.
Good Long Range Wireless Keyboard/Mouse Solution
By greymalkin in forum ComputerReplies: 3Last Post: 1st Apr 2012, 18:49 -
DVD Storage Solution ?
By xobituaryx in forum MediaReplies: 2Last Post: 7th Feb 2009, 23:00 -
Video data storage solution
By Diginosis1 in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2008, 07:59 -
Project storage solution questions...
By sdsumike619 in forum Newbie / General discussionsReplies: 6Last Post: 16th Mar 2008, 16:08 -
Need new (cheap) capture solution-what to get? Are TV tuner cards any good?
By wickeddvine in forum Capturing and VCRReplies: 1Last Post: 16th Jun 2007, 09:50
