Hi There,
is there an application available that can reliably tell me the audio codec an avi file has, e. g. when virtual dub says "unknown"?
Is there something like a FourCC available for Audio codecs, too?
Thanks for helping!
Regards,
NiteFlame
check the 'file information' in vdub. if it says 'unknown' and '5 channel' in some boxes, then you got a 5.1 ac3 stream.
Save it as a .wav file from vdub (audiostream.wav) then rename the extension to .ac3 (audiostream.ac3). Now open in Headac3he and convert to a real .wav - NOW you can encode it to .mp2 etc ...
if you want to know anything else ... sorry, thats all I know about 'unkown' audio streams ... -
ok, I found the solution:
http://www.hitsquad.com/smm/wwwboard/messages/110711.html
The problem was the missing divx audio codec. I never thought anyone would have ever used this one
Thanks anyway!
NiteFlame -
Too bizzare. I wonder If mine has the same problem. I can't determine what type of audio it is. It's not WAV, its not MP3, its not AC3. I did manage to get an error somewhere along the line that made it look like it was some sort of DIVX codec. The file was 'Sum of All Fears' DVD to DIVX rip.
Impossible to see the future is. The Dark Side clouds everything...
Please help: Virtual VCR not detecting Audio Device
By cnfcnf in forum Capturing and VCRReplies: 6Last Post: 30th Jan 2011, 13:17 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Detecting bad capture, detecting blank screen or static in video files
By dj22 in forum Capturing and VCRReplies: 1Last Post: 16th Nov 2009, 01:11 -
VideoReDo Not Detecting Audio
By MegaTonTerror in forum Video ConversionReplies: 3Last Post: 11th Nov 2009, 15:39 -
NoScript detecting spb.ru
By GMaq in forum FeedbackReplies: 0Last Post: 16th Aug 2007, 11:34
