  1. Hi folks,
    I am using Smartripper / DVD2AVI / TMPGEnc / Nero to create (X)VCDs from DVDs. This generally works great, I just do not get any subtitles that way. Is there a simple way to add one of the subtitle tracks from the DVD to the final MPEG-1 stream? Or if there is only a complicated way, which would that be? I am trying to avoid stopgap measures like in-between frameserving through VirtualDub or so.
    Thanks for any help.
    Robin
  2. MPEG-1 and VCD does not support Subtitles, if I'm correct.
    Frameserving with Virtualdub or Avisynt to add
    permanent subtiles will work with VCD.
  3. the only ways i know of to add subs (hardcoded, permanet) is through a framserver
    either vdub/vobsub or flaskmpeg
