Hi,
It was fine using DVDx 2.0 and Nero to burn my VCD on my p3 system. Now I have just upgraded to P4, the speed is amazing (from 5 hours to 2 and half hours). However, there is one small problem.
Now I used DVDx 2.0 to rip a DVD into VCD format, burn it using Nero express by choosing VCD. Nero will say that the file is not VCD complaint, and it spend about another 45 minutes to encode the file again. I never had this problem in P3 though.
Any idea, guys? Any help is appreciate.
Thanks in advance!
Results 1 to 1 of 1
How do I fit a DVD on one VCD with DVDx 4.0?
By Xoanon in forum DVD RippingReplies: 5Last Post: 27th Apr 2012, 02:20 -
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 10:31 -
Nero failure burning "Audio & Data cd"
By spiritgumm in forum AudioReplies: 4Last Post: 15th Oct 2008, 16:25 -
burning errors in nero & tmgenc dvd3
By brushuk in forum Authoring (DVD)Replies: 2Last Post: 13th Mar 2008, 11:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09
