No matter what mpg joiner I use the audio is messed up, it plays like its talking in slow motion while the video plays regular speed. Also the left side looks all distorted to. Does anybody have any Ideas of what might be wrong? Or have any suggestions on some good MPG Joiners I might use that might not have the same problem?
What exactly are you joining - mpeg1 or mpeg2 files.
Secondly have you checked that both mpegs are of the same
-frame size
-frames per second
-video and audio bitrate
If these do not match, then that is usually why you are failing. -
I'm trying to join MPEG1 Files. Also if that was the problem how could I change it so that both files are the same so I will be able to merge them?
If that was the problem you would have to choose one that you want as a standard and alter (re-encode) the other. Best thing to do is download "mpegproperties" in the tools section of this website and checkout which specs your mpeg's have.
ok tha tool does show that the mpeg1 are different. So how do I encode them to be the same mpg so I can join them together? If possible alot of detail so I can get it right.
I finally fixed it!! =) I just had to encode it to be the same and it works nicely =). Thanks for all your help I appreciate it alot. Well peace and thanks again.
Join multiple series of mpg files?
By Chasden in forum Newbie / General discussionsReplies: 17Last Post: 18th Sep 2014, 05:43 -
stuck for a program to join mpg's without reencoding
By orbspider in forum EditingReplies: 12Last Post: 8th Dec 2011, 10:57 -
need to join mpg clips
By volam1 in forum EditingReplies: 9Last Post: 23rd Nov 2009, 12:21 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57 -
Good free program to join .mpa audio and .mpg video ?
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2007, 09:34
