  1. It burns, and says successfull (sometimes it doesn't though). When it does burn one that says successful, and when I go to check the VCD, there is just a bunch of files on it. CDIEXT, MPEGAV (with a bunch of .dat files that do no open), SEGMENT and VCD files too. I'm about to throw my Nero software against a wall. Please help!
  2. that my friend, is NORMAL, a VCD can be read by a DVD player, you can also watch it on your comp, but you'll need a special reader for that... Look in tools, look for sumtin with DAT in... The REAL video file is the DAT file in the MPEGAV folder( i think,im not sure)
  3. If you want Windows Media player to open your .DAT files right-click on
    the file and select "Open With..."select Media Player and enjoy.
    In a VCD the main movie files are in the MPEGAV folder,in SVCD it's
    MPEG2.
  4. Banned
    Jun 2001
    UK
    You already posted this once in the Newbie Topic, dont re-post the same thing again.
    http://ww.vcdhelp.com/forum/viewtopic.php?p=348601&highlight=#348601
