Let's say I have this movie as an AVI.
As usual I saved the sound separately as .WAV with VirtualDub, then encoded the first half of the AVI to MPEG-1 with TMPGenc.
Then I did a second encoding setting the source range for the 2nd half. I used the same audio file I used for the first MPEG and the result is, that the audio and picture are out of sync, audio is behind in fact.
What did I do wrong and what's the correct way to do it?
Thanks a lot
I do not know what you did wrong, but you may want add silence to the end of the second audio file to re-synch it with your second video file.
Hello. -
Thanks for trying to help, but if you read again you will see that I wrote there is NO second audio file, just one containing the audio of the whole movie and I used it with both encodings.
I expected TMPGenc to be clever enough to find the correct position when encoding the 2nd MPEG, but somehow it isn't?! -
You may want to note exactly where the second video file begins, load the original video into Gold Wave.
Cut or Delete the first part of the Gold Wave audio. Save the remaining audio as a wave file.
Remux like you did the first video file, using the second voideo as input video, and your new wave file as input audio.Hello. -
Hey, that sounds like a good way to do it! I never used Goldwave before, but I will give it a try and let you know, what happened.
Splitting a .TS file in half
By danielmak in forum MacReplies: 4Last Post: 1st May 2011, 01:19 -
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 17:44 -
Need advice: Splitting simultaneous recordings contained in WMV file
By asawadude in forum Video ConversionReplies: 4Last Post: 10th Feb 2011, 20:48 -
Advice required - Formats, splitting, software, outputs
By glinscott in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2008, 08:00 -
Splitting avi file
By tryst1 in forum EditingReplies: 2Last Post: 15th Nov 2007, 04:33
