Is there a way to save the settings I set up so I do not have to reset it up each time?
"Computers are stupid, but they are capable of being stupid one million times per second"
AnonymousGuest
Look around, there are two places, one for capturing and one for processing or editing, each is accessed from that same screen, ie, one for editing is the first screen under file called save or load processing settings and the other is in the capture avi screen under capture called preferences, click each one there to save your settings as the default. They stuck for me.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Settings Xvid codec in Virtualdub
By Docoptik in forum SubtitleReplies: 7Last Post: 6th Mar 2011, 15:15 -
Virtualdub settings to capture DV
By magillagorilla in forum Capturing and VCRReplies: 12Last Post: 11th May 2010, 14:42 -
Help with Best x264 Settings and Virtualdub Avidemux
By ZZen in forum EditingReplies: 13Last Post: 9th Jun 2009, 09:48 -
If VirtualDub capture, which one and what settings?
By tluxon in forum Capturing and VCRReplies: 3Last Post: 20th Jan 2009, 21:05
