  1. im having problems with maestro - i ripped dvd - re-encoded to smaller size - ripped subs with subrip and chapters with chapter xtractor - i try to import chapters into maestro along with m2v and ac3 - ac3 and m2v go into timeline with no problems - but when i import the chapters it only uses 6 of the 22 chapters in the chp file and they dont seem tobe the same as original chapters - also does the same with the subs only 162 of the 642 subtitles - CAN ANYONE PLZ help me with this - i will have no hair left by the end of the week - i have looked for threads on this and there seems to be none so i guess im the only one with the problems HELP!!!HELP
    Aug 2002
    England
    I had the same problem except I got NO chapters OR subtitles. I found that if you re-encode the video file only with TMPGEnc then all will fall into place.
  3. the problem can be solved this way:
    use CCE manually(Robshot method) and save the project (*.ecl) and shutdown CCE... then use ChapterXtractor and and load the main movie IFO, then go to the Format tab and define a new format:
    Presets -> CCE
    Format: -> chapter=%f:
    leave others blank!
    You then should have something like this:
    chapter=0:
    chapter=19035:
    chapter=28224:
    chapter=48132:
    chapter=62046:
    chapter=74529:
    chapter=94153:
    chapter=102532:
    chapter=122404:
    chapter=139381:
    chapter=155191:
    chapter=165919:
    chapter=184153:
    now copy this and open with notepad that CCE Project file *.ecl and paste those chapter's end of that file and Save...
    Now open CCE again and open that *.ecl file and Encode... after this you should NOT have ANY problems with chapters or subtitles with DVDmaestro...
    Zzzzzzzzzzz
  4. Thnks m8 i just noticed ur reply - will try this - what im actually trying to do is - author it then use ifoupdate and put it back to original menu will this method work ? if not what could i use to put encoded vid back to original Menu
  5. k i use dthe chapter method of loading the frames into the ecl file for CCE all went well chapters loaded correctly Into DVDMaestro - i ripped the subs with subrip - and they SAY this - No Corresponding Subtitles found - The Video Asset Timecode may not correspond to the timecode specified for the subtitles in the Import File- am i doin summit wrong with subrip?
    or the encoded file?
    i didnt close gops could thios be the problem?
    Adder78 m8 i ned ur help again Plz
