Ok guys, this is the thing: I am making VCDs out from the films I have here in my computer. And I was just wondering...
Am I supposed to make 1150kbps VCDs? I mean, do I HAVE to choose 1150 or can I make this number higher, since I want a better quality VCD? Does DVD Players with VCD support support a higher VCD bitrate? thx
elMister
you find quality important, well i suggest you make SVCDs then, cuz they have much better quality than VCDs. and i won't look THAT much at the bitrate, you better go for a constant quality
btw, what program do you use? I sggest you use TMPG
good luckWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
yep, I use TMPG. But I think my DVD doesnt support SVCDs
once again, can I higher the bitrate of a VCD?elMister -
Yes, could try something like 1500 (instead of 1150)
also check: "mpeg-1 video-CD (non standard)" in tmpgenc
Turn Compliance off on Nero.
But you will fit less minutes on the CDR.
It may not play in your DVD player as it is not a standard VCD
(or it will play in yours but not in your friends player)
Was I supposed to get soundforge 10 with Vegas 9.0?
By solarblast in forum AudioReplies: 0Last Post: 13th Mar 2011, 22:50 -
Cut Assistant not working the way it's supposed to
By jeanmarc in forum EditingReplies: 3Last Post: 3rd Dec 2010, 04:47 -
Is it supposed to take this long?
By blaqlion22 in forum Authoring (DVD)Replies: 1Last Post: 20th Jun 2009, 07:41 -
Supposed copyright blocking transfer
By sydman in forum ffmpegX general discussionReplies: 2Last Post: 9th Jul 2008, 00:25 -
My videos play at a different resolution than they are supposed to?
By darkzero297 in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2007, 14:00
