I have a video file that is already in MPEG format. Can I just burn it to VCD or does it need to be converted? Also, how do I tell what version MPEG it is? Like MPEG1 or MPEG2???
Thanks guys!
Jim
Now you start your burning program(nero for example) and you can use that file as the source file for your VCD
How to tell? Well, You can use virtualdub to see it: Open the MPEG file, FILE -> FILE INFORMATION
but usually, if the file is an MPEG file, it's MPEG-1, if it's MPG it's mpeg2, but that rule isn't allways rite, VDUB will show you!
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 05:31 -
Need mpeg-1 to VCD tool that splits
By anadiner in forum Authoring (VCD/SVCD)Replies: 14Last Post: 4th Dec 2009, 05:24 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 23:55 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
