when I load the d2v file for the video part and then have to load the audio file, which file is it? the encoded audio.mp2 file or the extracted audio.ac3 file? Becuase Tmpeg will only let me do the .mp2? is this correct?
thanks
dvd2avi should've only decoded 1 audio track (the audio track u selected in dvd2avi). it should be a wav file.
in dvd2avi, did you tell it to decode dolby digital (rather than demux)? -
poopyhead,whenever i use dvd2avi I select audio track no.1 and it always comes out as an ac3 file, not a wav am i doing something wrong?
I usually let DVD2AVI change the audio to 44.1KHz by selecting Dolby Digital then decode, and 48->44.1KHz to MID. You can experiment with the other settings, but usually MID works for me. It will take longer for DVD2AVI to finish though. I know there are better ways to decode the audio, but I'm lazy and like having the same program do both.
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 13:05 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 15:18 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 17:42 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 20:53 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 17:53
