Hello everyone, I am trying to play VCD on toshiba 2109 but having no luck due to the fact it says it does not read them, I have been told that it will work with certain branded cdr`s but don`t know which one OR is there any hardware crack to make it play them
Thanks.
Hi,
I too have a Toshiba 2109 and cannot get any CDR's or CD/RW's to work. I have tried CDR; Verbatim, Memorex and Sirius so far. For the CD/RW; Verbatim and Yamaha.
I used Nero to convert mpeg to VCD. Plays the VCD fine on the computer but not on Toshiba. Maybe I am doing something wrong. Not sure, since I am new to this. My one question is when using Nero after I drag mpeg over it lists as track 2. Could this be the problem? Does it have to have a track one as menu? I have looked thru the Author helps but cannot find a solution. Please help. TIA
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Is Toshiba Going out of Business?
By wulf109 in forum Off topicReplies: 7Last Post: 3rd Jun 2009, 02:42 -
Toshiba SD120E
By dodger1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Sep 2008, 08:56 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:57 -
Help with the Toshiba SD 5000
By boub in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Jun 2007, 16:51
