Hi All,
I converting some AVI files to MPEG Format. Is it usual for MPEG file to be pretty big.
I.E Avi File = 5mb -> Mpeg File 20mb
no, avi files are way larger. mpeg2 (dvd & svcd) has a much smaller file size with little or no loss in quality from the original file. mpeg1 (vcd) is smaller yet, and you will notice less quality (quite a bit) than the original avi file.
so how come when i convert a avi to mpeg using TMPGEnc and following the VCDHelp Guide i get a mpeg file that is huge
Thanks -
taurusthebull said:
Not often true I am afraid. AVI is simply a wrapper format and can contain video and audio encoded in many different ways and at many different resolutions. True, uncompressed avi, or lossless compression, tends to be much bigger than an equivalent mpeg (same movie length, same resolution etc). However, nearly all avi's found on the net, esp on newsgroups, P2P etc are encoded using one of the divx codecs or a derivative. These are based on the mpeg-4 format and are much more compressed than any mpeg-1 or mpeg-2 files. Hence converting one of these files from mpeg-4 in an avi wrapper to mpeg1/2 will cause the file size to grow in nearly all cases.avi files are way larger. mpeg2 (dvd & svcd) has a much smaller file size with little or no loss in quality from the original file
fordster If creating VCD compliant mpeg files, 1min of video is approx 10Mb in size. For more info on this format take a look at
http://www.vcdhelp.com/vcd
Hope this helps
MPEG-2 528x576 to AVI conversion problem.
By madman1987 in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:53 -
Sound lost after conversion mpeg to avi
By maclinux in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 13:47 -
Quick .avi Conversion to MPEG-2 ?
By christopheramos in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 18:42 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 00:49
