Hi guys![]()
I am using my gainward GF4 golden sample hooked up to a VCR to try to capture video, i am using Ulead Video studio 6SE, and intervideo wincoder, but when i choose input source as S-Video i get an image, although its black and white, but when i switch to composite the picture is colour. I am guessing if i get the input from S-Video then the image will be better ??
many thanks for any help
Hi Tommy
thanks for replying
there is a scart out box on the VCR, which splits the signal into composite, S-Video, and audio, its connected to the Card with an S-Video cable, thats allows a composite signal, and an S-video one.
make sense !?!?
athlon,
sounds like you need to set up your software cap app to PREVIEW mode
instead of OVERLAY. Turn off OVERLAY. I could be wrong, but whenever
you use (usually) S-Video as your input source, OVERLAY doesn't work
properly and will only give you B/W signal of video.
ie, when using AVI_IO or VDUB, is S-Video is selected as my source, and
I have OVERLAY on, it w/ be in B/W.
However, if I first:
* turn on or select PREVIEW in any of these two capture apps, and THEN
select S-Video, my video is color.
S-Video?? Well, I'm affraid you're guess kind of wrong.. ..
As for S-Video being the better quality, you're slightely confused as
many others here. In any case, w/ standard VCR mode, S-Video vs. Compsite
yields no difference. Now, perhaps, if you had/have an S-VHS AND, am
using an SVHS tape (recorded in SVHS mode on your S-VHS VCR, and of
course, in SP mode) you may see a difference. But to be quite honest
w/ you, even so, you really wont notice much difference between the
two for sources coming from a regular/standard VCR. Try not to ware
yourself out on this issue though.
In my expience, S-Video tends to create even more noise for VCR sources.
I said, in my experience.
-vhelp -
Since you mentioned scart.... make sure your software is set to capture PAL video. Not NTSC. But you probably know that already.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
S-Video is designed to give better seperation and less crosstalk-type interference than coax or composite. It is generally accepted to be superior to anything except component, as a cable type.
However, simply having the connection available does NOT, in and of itself, offer any improvement to your basic equipment. You can't polish a turd.
The black and white image does sound like a PAL problem, I am in NTSC land but I have seen this described many times. Although why it would work in composite is odd, are there different settings for each connection type?
Grey video panes on Virtualdub
By kamepi_chan in forum EditingReplies: 24Last Post: 24th Oct 2021, 04:18 -
Virtualdub grey line on right side of video?
By Snorklex in forum Video ConversionReplies: 5Last Post: 27th Sep 2010, 06:49 -
Converting to FLV results in jumpy, grey 'solarized' video
By snoogly in forum ffmpegX general discussionReplies: 1Last Post: 31st May 2009, 18:46 -
Grey hair - WTF?!
By Xylob the Destroyer in forum Off topicReplies: 21Last Post: 16th Mar 2009, 18:58 -
Black is Grey... Sometimes
By yukon33 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2008, 00:53
