hey
is there a way to change the framerate of an mpeg file without reencoding it? i have a file where the sound is a little off, and as i've tested on virtualdub it will be fine if i reduce the framerate a little. i don't intent to burn a VCD or anything, so it's not a problem if the frame rate isn't 29.97.
so, is there such a program?
thanks for your help!
Results 1 to 1 of 1
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 11:35 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 02:32 -
2 videos with different frame rate sync problem
By dgiulian in forum Video ConversionReplies: 1Last Post: 26th Mar 2011, 20:40 -
Help converting mpeg type video with correct frame rate
By DJX in forum Video ConversionReplies: 0Last Post: 9th Oct 2010, 18:24 -
Video out of Sync, Frame rate question
By jin007 in forum Newbie / General discussionsReplies: 6Last Post: 11th Jul 2008, 13:17
