Need help playing tft files can someone help me with this problem. I checked the properties of this file and it shows it is a Dos-AVI file. I am running windows 98 SE. I have tried opening the file with windows media player and real player. I get a black screen and no audio or video. But it shows the time of the file and the play bar moves as though it is playing the file. I have installed the Nimo 5.0 Build 5 codes.
Thank You,
Vacman
I think the better question is what is an tft file? I've never heard of it, at least not on the Windows platform. Is this some file format associated with the MAC or Linux OS's? If so you might be better served by posting this in either of those forums.
Warning! I'm baaaaaaaaack -
vacman37,
Hmmm??? Edited your original post eh? None-the-less that's not a file format native to the Windows OS and I've been banging away since the good old days of 3.1 and when 14.4k modems were considered broadband.Warning! I'm baaaaaaaaack -
If you have the correct codec's then chances are you have downloaded a "Fake"Originally Posted by vacman37
Load the AVI into Vdub and select file > file information this should tell you what is being used. If Vdub does not complain about unsupported then it sounds like a fake.
More here
http://www.vcdhelp.com/forum/userguides/116924.php
Why won't my TV play certain MKV files?
By MrFriendly in forum DVB / IPTVReplies: 27Last Post: 24th May 2016, 15:00 -
PS3 won't play some MP4 and AVI files
By jiggy in forum Media Center PC / MediaCentersReplies: 4Last Post: 14th Feb 2010, 20:22 -
AVI files won't play in anything but VLC
By zanos in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2009, 22:07 -
Certain XviD files won't play
By Towin in forum Software PlayingReplies: 2Last Post: 10th Dec 2009, 19:01 -
Some video files and movie files won't play
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 21st Feb 2008, 11:08
