im following the guid at
http://www.vcdhelp.com/ATI_AIW_Guide.htm
and i make it to the last section
Re-multiplexing ATI MMC 7.1 captures for total VCD 2.0 compliance.
specifically with step 7 and on... what is this VCDMUX and why cant it be found any where
does any one else have the ATI All-In-Wonder and is able to help me... thanx in advance
eddie
ratz,
Looking at that guide you mentioned it appears to somewhat dated and to be honest I never heard of VCDMUX till your post. If your already using TMPGEnc there's no need for a separate utility to remux your file. Just use the mpeg tools listed under the file tab of TMPGEnc. Make sure you select "MPEG-1 Video CD" next to "Type" under the multiplex tab, select your input and out files and hit run. That's all there is to it.Warning! I'm baaaaaaaaack -
I have been using ATI All In Wonder for quite some time now, I never had the necesity of remultiplexing, I just drop the file in nero and burn the VCD. Of course you have to update the registry using MMC Registry Tool, and you will have a standard compliant VCD File.
! Viva Mexico !
Needing a new camera under $700
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 70Last Post: 7th Sep 2009, 15:11 -
needing codecs?
By 2mmy in forum Software PlayingReplies: 3Last Post: 22nd Mar 2008, 12:27 -
Needing a Video Editor for PC
By designbuyers in forum Newbie / General discussionsReplies: 14Last Post: 20th Feb 2008, 03:07 -
needing help with HD movies
By mahfuz in forum Newbie / General discussionsReplies: 0Last Post: 6th Oct 2007, 08:57 -
Needing a new Burner
By Burn it up in forum DVD & Blu-ray WritersReplies: 6Last Post: 21st Jul 2007, 23:52
