I have encoded some avi files in tmpeg to svcd with no problems.. When I try to convert some other avi files I keep getting an error at the begining of the conversion. If I convert the audio to a wave file in virtual dub then use that for the audio source it works but the mpeg audio is always out of sink when I burn it to a cd. Can anyone tell me the best way to fix the audio sync problem ..
theres a facility within tmpgenc to correct any audio/video synchronisation errors. its on the source range page at the bottom. hope this helps
I have used the delay audio in the source range setting and got it to match up with the vidio when I play the mpeg on my computer but when I burn the mpeg to svcd the audio is still out of sync.. HELP ANYONE!!!!!
I have also corrected the audio vidio sync with virtual dub .. But I get the same results when I write the mpeg to svcd ...
Originally Posted by andyozzy
See my other posts on using "Vdub MP3" if you get problems with normal Vdub
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 16:20 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 06:23 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 13:01 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 04:31
