I am trying to capture with my Hauppauge WinTV PCI-FM for 2 months now, I used VirtuaDub, Adobe Premiere and The WinTV included (shit) but I always get a amazing desync after about 10 mins of recording. Can anyone share experience with that card and capturing, what the best prog is and what th erbest settings are. Thanx in advance ppl, please help!
Bock
in what resolution are you capturing and whats your system configuration (processor, hdd and ram)?
using virtual dub make sure you have "lock video stream to audio" under capture/settings and "adjust video clock..." under capture/timing enabled. also have a look whether you have set the correct framerate.
though i`m pleased with virtualdub a lot of people here use AVIIO for capturing; try that, too.
System Information: Windows 2000 Professional, Service Pack 2 (5.0 - 2195)
CPU: 1-AMD Athlon K7, 902MHz
Memory: Usage: 182/768MB (23.70%)
Display: 1024x768 32bit 60Hz
I get desync in all Resolutions... VirtuaDub is the only program with dropped frames I dunno why. I alredy did these settings but it won't work
What codec and color format are you using? Try using AVI_IO to capture in 320x240 in YUY2, optionally with Huffyuv. If you're overclocking, try returning your CPU to its rated speed. Also, make sure you have the latest VFW WinTV drivers from Hauppauge.
AVI_IO is available from here, BTW:
http://www.nct.ch/multimedia/avi_io/
-Cart
http://www.geocities.com/lukesvideo/index.html
Samsung BD-D5500 Audio/Video DeSync During MKV Playback Over USB
By Anonymous8443434 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 11th Jul 2012, 21:34 -
Questions about Hauppauge 1196 WinTV HVR-1250 PCI Express Card
By Wizard23 in forum Capturing and VCRReplies: 15Last Post: 25th Feb 2011, 15:22 -
No Audio On QAM Channels With Hauppauge 1800 and WinTV 6
By DarrellS in forum Capturing and VCRReplies: 0Last Post: 15th Jan 2011, 00:08 -
capturing video with Hauppauge wintv-hvr-950q
By lmemsm in forum Capturing and VCRReplies: 5Last Post: 2nd Sep 2009, 20:17 -
Considering Hauppauge WinTV PVR 350...
By chewie8008 in forum Capturing and VCRReplies: 9Last Post: 2nd Oct 2007, 17:20
