Trying to rip Scorpion King with easy vcd. and as it runs, I keeps "skipping vob-id..." down the line untill it says there was a problem ripping the dvd... etc.
I have tried playing the dvd and going through the chapters but still no good?
any help would be greatly appreciated.
thanks
ripped scorpion king w/ smartripper no problems...try using another ripper...also, try cleaning the bottom (scratches, dirt, etc.. might cause problems)
could be your dvd drive I have a Liteon 16x dvd which is useless for alot of dvd it just won't rip all of them as it comes up with errors. I gave a 16x Pioneer and it has ripped every dvd I have tried. The Liteon fails on 30% that I have tried.
i've heard only good comments about the liteon drive...did you try upgrading your firmware? how about aspi?Originally Posted by sporlan
Can a Anydvd rip actually be bad and cause skipping?
By AndyD in forum Blu-ray RippingReplies: 4Last Post: 11th Apr 2010, 20:38 -
Strange VOB skipping issue
By archaic0 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2009, 12:25 -
VOB files skipping
By Mindg in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2007, 22:27 -
Perfect VOB files of movie skipping when burned
By oinkyboinky in forum Authoring (DVD)Replies: 14Last Post: 29th May 2007, 08:51 -
Problem with recorder? Skipping only when recording on DVD
By fastheart in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2007, 10:26
