I need major help...every time I burn 2x practically, only certain files are readable back to the disk. Often towards the end, the vob files towards fail crc when I try to copy them back to the hard drive ON THE SAME BURNER THAT BURNED THEM! Is my burner screwed? Or has anyone else encountered this. I was tempted to remove my burner and smash it to bits with a hammer, so many dvd-r's I have wasted (TDK and Verbatim 2x certified). 1x has no issues. I am burning with Prassi PrimoDVD.
TIA for any help.
