This problem is more file orientated than anything, but I didn't know where to ask it. Every time I have downloaded movie files recently, usually 1 out of every 3 works. It tries to download codecs, with no success, or just plays a blank screen, or no sound.
Is there software that I should get?....or are these files just corrupted? Any help would be appreciated.
Thanks,
Steve
You could always download a codecs pack such as Nimo Codec pack:
http://nimo.everwicked.com/ or maybe your files are just corrupted, in that case you can always try to fix them with DivXFix: http://www.divx-digest.com/software/divfix.html...Hope this helps... -
i agree, download the nimo codec pack but choose the light version, cos i believe the full pack contains spyware
You do have to be careful, there are lots of fake movies out there, so you should use the verified movies, and Sig2Dat that way your are guaranteed the movies are correct. Having said that, you will need many different types of codec's before you can convert, sometimes you will be able to play but not convert.Originally Posted by Viceroy
More info here
http://ww.vcdhelp.com/forum/userguides/116924.php
AC3 .avi files trouble playing the sound in WINAMP
By NEVERMORE in forum AudioReplies: 0Last Post: 13th Sep 2010, 23:27 -
trouble playing dvd
By speedoman955 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Dec 2009, 08:08 -
Trouble Playing or Editing Matrox HD AVI files past 10 minutes
By SCDVD in forum EditingReplies: 0Last Post: 29th Mar 2009, 13:07 -
Having trouble playing 1080p
By godvsnietzsche in forum Software PlayingReplies: 8Last Post: 24th Nov 2008, 19:09 -
trouble playing .avi files
By starkythesparky in forum Software PlayingReplies: 5Last Post: 12th Jun 2008, 23:54
