I can't seem to find the settings so that I can split an avi into 2 mpgs, but with almost no or very little detrioration in quality. Every time I extract half of it so I can burn to VCD, some video quality is lost.
Can anyone help?
You can use the source range to encode half at a time, or use the Merge&Cut to split what you already have.Originally Posted by Ewlesy
When using Merge&Cut you need to select "MPEG 1 Video CD" from the drop down list, However if you had a higher bitrate greater than 1150, in other words you had a XVCD then this streaming would correct that error, and reduce the quality.
You should always use a VCD template when encoding, that way the Merge&cut will not effect the output in anyway.
Oh and "These settings above" is a bad link, he needs to edit
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 22:10 -
Tmpgenc DVD Author 3 Custom Background Quality?
By haym in forum Authoring (DVD)Replies: 1Last Post: 29th Jul 2008, 19:49 -
TMPGEnc advanced settings for best quality results
By tdavid232 in forum Video ConversionReplies: 1Last Post: 15th May 2008, 19:02 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 13:15 -
What are the current encoders comparable to tmpgenc in quality?
By inuyasha in forum Video ConversionReplies: 24Last Post: 26th Jun 2007, 06:43
