Have Hp200i and want to put Divx movies on DVD format with DVD-R,tried basically all the guides but what is fast and less time consuming?
There really is no "fast and less time consuming" way to do it right. You can either drop your Divx files in a DVD authoring program (like DVD Workshop) and have it render the files and burn the disc, or, if the authoring program doesn't like your Divx files, you will have to first render them in something like TMPGenc and then drop them in the authoring program.
no matter what it will take time, read guides, try them out, then you can find what you find is the easiest way. plus wrong forum.
I would check out www.Doom9.net actually. Read their guides, try things out so you get the feel for it, then see what fits you best. Their forums are a good place to do searches and read up also.
Easiest anymation
By jimmyy in forum EditingReplies: 10Last Post: 19th Jul 2012, 15:20 -
Easiest way to record from TV to computer?
By sdsumike619 in forum Capturing and VCRReplies: 4Last Post: 6th Oct 2011, 00:08 -
Please help me,Dvd to mpeg,The most easiest way!!
By adrianneow in forum Video ConversionReplies: 2Last Post: 7th Jun 2011, 08:09 -
easiest way to trim captures ?
By Tafflad in forum Capturing and VCRReplies: 8Last Post: 14th Feb 2010, 14:24 -
Easiest Cutting Program?
By Merkaba188 in forum EditingReplies: 9Last Post: 4th Nov 2009, 21:25
