    Oct 2002
    Philadelphia
    When I try to load the d2v file onto tmpge it says it is unsupported. IT will take the vob files , but only one at a time. But I thought you were to use the dv2 file. What am I doing wrong.. Is there a reason it is not recognizing the rip file??????
    Apr 2002
    The State of Frustration
    In the environmental settings, is Direct Show's priority higher than the rest, at least 2 or higher?
    Hello.
  3. Did U install the VFAPI plugin for TMPGenc?
    If not...u can find it at
    http://www.tmpgenc.net/e_vfapi.html
    There is a known problem that sometimes occur when u start decoding with TMPGenc....if so....uncheck DirectShow Multimedia File reader.
    U can find this in Options---->environmental Setteing--->VFAPI plugin
    For more help this is a good guide
    http://www.doom9.org/mpg/tmpg-main.htm
    Goodluck
